[GRASS5] r.mapcalc and NULL question
Eric G . Miller egm2 at jps.net
Mon Jan 15 14:02:04 EST 2001
Or just use the if() construct in r.mapcalc.
echo 'streams.2 = if (isnull(streams),-9999,streams)' | r.mapcalc
or something like that.  I've used this more than a few times to create
mask layers.
On Mon, Jan 15, 2001 at 10:39:55AM -0700, William L. Baker wrote:
> You can use r.null to turn the nulls into zeroes,
> then use r.mapcalc to give values where there is a 0.
> But, maybe you were thinking it would be better to
> modify r.mapcalc to do this...
> Bill Baker
> -----Original Message-----
> From: Markus Neteler [mailto:neteler at geog.uni-hannover.de]
> Sent: Monday, January 15, 2001 11:04 AM
> To: grass5 developers list
> Subject: [GRASS5] r.mapcalc and NULL question
> Hi there,
> maybe a r.mapcalc/NULL FAQ, but I don't get it...
> Assume you have a streams map (streams contain values,
> other cells=NULL).
> Now I want to add some values *everywhere* using r.mapcalc, but
> it is only added in those cells not containing a NULL value.
> Any ideas how to overcome this problem?
> Thanks in advance
>  Markus
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
