[GRASS5] html to man conversion
Justin Hickey
jhickey at hpcc.nectec.or.th
Mon Jan 15 07:24:36 EST 2001
Hi Markus
Markus Neteler wrote:
> > > Hi again,
> > > unfortunately another bug found on SUN in
> > > html/Gmakefile
> > > Copying html pages
> > > /bin/sh: test: unknown operator -ot
> > > I don't know the meaning of -ot, but it's not portable
> > > (Huidae, Michel?).
> > Uh ? excerpt from SunOS 5.7 man page of test
> > file1 -ot file2
> > True, if file1 exists and is older than file2.
> > BUT... [ or test are in /usr/ucb or /usr/bin for sun =>
> > $ if /usr/bin/test Lespinard.zip -ot Duclaux.zip ; then echo ok ; fi
> > ok
> > $ if /usr/ucb/test Lespinard.zip -ot Duclaux.zip ; then echo ok ; fi
> > Conclusion :
> > if test file1 -ot file2 ; then echo ok ; fi # doesn't work
> > if /bin/test file1 -ot file2 ; then echo ok ; fi # works !
> > Silly mixing of old SunOS and new Solaris versions... !
> I have checked that. And I have renamed
> /usr/ucb/test
> to
> /usr/ucb/test_old
> .. but above problem is still there.
> The "-ot" test occurs from
> html/Gmakefile:
> if [ ! -f $$f -o $$f -ot $$h ]
> So "test" is not called directly. How can we fix this?
It has to be changed since the -ot option is not supported on SGI
machines. Perhaps we could use the getModTime function I added to
src/general/init but then it would need to be compiled before the html
conversion.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
