[GRASS5] shade.rel.sh bug?
Andreas Lange
Andreas.Lange at Rhein-Main.de
Fri Jan 12 16:14:07 EST 2001
Thank you very much.
Works now without any problems!
cu,
Andreas
Markus Neteler wrote:
> On Fri, Jan 12, 2001 at 04:36:26PM +0000, Markus Neteler wrote:
> > On Fri, Jan 12, 2001 at 04:22:56PM +0100, Andreas Lange wrote:
> > > Hi,
> > > the shade.rel.sh script does IMHO not work properly any more.
> > > If i create a shaded relief in plain areas (even surfaces/no slope)
> > > there are NULL-holes in the raster. My DEM has no NULL-values.
> > > I think that this comes from different handling of division by zero?
> > > This has maybe a very simple solution (if-clause in the mapcalc
> > > function?), but i don't know which.
> > > I'll report this to the RT if i get no feedback for a solution.
> > > Just removed my grass4.3 setup, so that i can no longer test.
> > Hi Andreas,
> > I have already a fix - will check in now.
> > In a few minutes...
> Done :-)
> cvs up src/scripts/shells/shade.rel.sh
> Please try. Congrats evetually to David Finlayson <david_finlayson at yahoo.com>
> Cheers
> Markus
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
