[GRASS5] optri ?
Andreas Lange
Andreas.Lange at Rhein-Main.de
Fri Jan 12 07:00:48 EST 2001
Hi Markus, hi Bernhard,
optri was removed because of copyright issues that could not be resolved
to be compatible with GPL. So the message in the BUGS file about the
optri problem is obsolete.
With detri the license is ok, but there is a another library part of
detri that is not compatible with GPL. This part has to be removed and
changed to c standard library functions.
Next the detri library has a different structure than optri, so that a
simple search & replace or wrapping the library won't work. I have no
clue how much work this is and if/how detri can be adapted to GRASS.
Generally i think that GRASS needs one library for computational
geometry that provides functions that operate on the GRASS data. If
detri is adapted to GRASS in the same way optri was this would be only
another 'hack' to provide some functionality for some stand-alone
modules, but not usable for general programming.
I already wrote down what functionality IMHO is needed, if i find the
mail again i will check the text in for CVS.
cu,
Andreas
Markus Neteler wrote:
> On Tue, Jan 09, 2001 at 01:24:29PM +0100, Bernhard Reiter wrote:
> > On Mon, Jan 08, 2001 at 06:02:41PM +0000, Markus Neteler wrote:
> > > what is the current status of optri integration?
> > > Shall I or not? Any more copyright problems here?
> > The problem I have found out are still there, AFAIK.
> > We have to replace most of the code with detri or something else.
> > I don't know if anybody already started with this.
> Excuse me - I wanted to write: detri!
> So... shall I check in detri? Any objections? Do we need it? :-)
> Markus
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
