[GRASS5] Severe (simple to fix?) problem with current GRASS
Andreas Lange Andreas.Lange at Rhein-Main.de
Fri Jan 12 07:18:08 EST 2001
i agree with removing the alpha and contrib distinction.
But i am not shure if it is wise to remove the cmd and inter(active)
distinction.
The command line and interactive modules have to be distinguished
somehow and the setup worked perfectly. Why replacing a working setup
with something else that causes a lot of work?
Just my opinion on this.
I have to look if my dejagnu testing suite is affected and fix.
cu,
Andreas
Justin Hickey wrote:
> Markus Neteler wrote:
> > Hi all,
> > after changing all Gmakefiles I have seen that
> > GRASS doesn't start any more :-)
> > ERROR: program 'g.gisenv' cannot be executed because:
> > Neither a command line (cmd) or interactive (inter) version was found
> >    in any of the main, alpha, or contrib directories.
> > This should be simple to fix as the
> > src/front.end/main.c
> > needs to be updated to reflect the removed main, alpha, or contrib
> > directories (real_path variable). However, I can't manage this...
> > Sorry, expert wanted. generally it should be simple to fix (I got
> > lost with all the pointers and lists there).
> Working on it now.
> Sincerely,
> Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
> High Performance Computing Center
> National Electronics and Computer Technology Center (NECTEC)
> Bangkok, Thailand
> People who think they know everything are very irritating to those
> of us who do.  ---Anonymous
> Jazz and Trek Rule!!!
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
