[GRASS5] Re: all INTER broken
Markus Neteler
neteler at geog.uni-hannover.de
Fri Jan 12 10:21:01 EST 2001
Hi Justin,
yes, I got it!! The front.end is fixed. I have added
some DEBUG stuff which can be switched on/off (hope that's ok.).
Reason for the problem was that
cmdLine = FALSE;
had to be defined. Obviously is was true by default on Linux, so
all commands were treated as CMD.
Now it's o.k. here, everything runs fine with the updated Gmakefiles.
Cheers
Markus
PS: Hi all, please update src/front.end/, then (to be sure)
make distclean
make
make install
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
