[GRASS5] Severe (simple to fix?) problem with current GRASS
Markus Neteler
neteler at geog.uni-hannover.de
Wed Jan 10 13:21:07 EST 2001
Hi all,
after changing all Gmakefiles I have seen that
GRASS doesn't start any more :-)
ERROR: program 'g.gisenv' cannot be executed because:
Neither a command line (cmd) or interactive (inter) version was found
in any of the main, alpha, or contrib directories.
This should be simple to fix as the
src/front.end/main.c
needs to be updated to reflect the removed main, alpha, or contrib
directories (real_path variable). However, I can't manage this...
Sorry, expert wanted. generally it should be simple to fix (I got
lost with all the pointers and lists there).
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
