[GRASS5] new vector2
Radim Blazek
Radim.Blazek at dhv.cz
Fri Jan 5 05:52:14 EST 2001
Michel Wurtz wrote:
> "Eric G . Miller" wrote:
> > As was mentioned, maybe it is possible to always write data in native
> > format, but perform a byte swap conversion on read if necessary. It
> > would require a bitfield or such to specify endianness. I don't know if
> > this would cause more headache than it's worth, since partial
> > updates/writes would also need a conversion check. Maybe it's just
> > better to choose one and live with the conversion slow down.
> > > 2) It is possible to compile version 4 vector library with #define
> > > NO_PORTABLE and all vector files will be written in native format
> > > instead of portable. Speed on little endian machine is increased but
> > > such non portable vector files may be not be used on big endian
> > > computer then. Somebody ever used such option? Should be this
> > > feature keept in new vector format/library? My suggestion is do not
> > > support that option and be sure that all vector files in the world are
> > > always portable.
> > I agree with dropping it.
> Another solution is always write data in native format with a flag to
> specify endianness and have a program for converting from one format
> to another. This means also that we must detect if a file doesn't fit
> the machine endianness, in order to to call the conversion program
> inside the open function. The slow down is then limited to the first
> open...
Thank you for your comments.
My conclusion is:
- vector file may ben written in big or little endian (no pdp or other)
and byte order is specified in header
- by default new file will be written in machine native byte order
(later add optional byte order for new files by enviroment
variable GRASS_VECTOR_ENDIAN)
- vector modules (library) will work with both little and big endian vector files
- write new module for conversion little <=> big
- no auto conversion into native format (read only files, files shared by
more platforms)
- vector written in one byte order (big for example) will be updated in that byte order
(big) even on machine with some other byte order (little)
OK?
Radim
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
