[GRASS5] new vector2
Michel Wurtz
mw at teledetection.fr
Fri Jan 5 05:05:11 EST 2001
"Eric G . Miller" wrote:
> As was mentioned, maybe it is possible to always write data in native
> format, but perform a byte swap conversion on read if necessary. It
> would require a bitfield or such to specify endianness. I don't know if
> this would cause more headache than it's worth, since partial
> updates/writes would also need a conversion check. Maybe it's just
> better to choose one and live with the conversion slow down.
> > 2) It is possible to compile version 4 vector library with #define
> > NO_PORTABLE and all vector files will be written in native format
> > instead of portable. Speed on little endian machine is increased but
> > such non portable vector files may be not be used on big endian
> > computer then. Somebody ever used such option? Should be this
> > feature keept in new vector format/library? My suggestion is do not
> > support that option and be sure that all vector files in the world are
> > always portable.
> I agree with dropping it.
Another solution is always write data in native format with a flag to
specify endianness and have a program for converting from one format
to another. This means also that we must detect if a file doesn't fit
the machine endianness, in order to to call the conversion program
inside the open function. The slow down is then limited to the first
open...
Michel WURTZ - DIG - Maison de la télédétection
500, rue J.F. Breton
34093 MONTPELLIER Cedex 5
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
