[GRASS5] v.digit dumps core
Roger S. Miller rgrmill at rt66.com
Thu Jan 4 13:55:58 EST 2001
Justin,
This bug apparently does not effect Grass 5.0 beta 10 on Linux w/egcs.
The M_edit structure is initialized in src/mapdev/v.digit/menus.i, which
is included in src/mapdev/v.digit/menus.c
Upon entry into the loop at digmain.c line 312 the M_edit.item[0].text and
subsequent entries are initialized with menu item text for the Edit menu.
Sorry I can't be more helpful.
Roger Miller
Lee Wilson and Associates
On Thu, 4 Jan 2001, Justin Hickey wrote:
> Hello all
> Some of you already know that v.digit dumps core on my SGI machine when
> I confirm that I want to continue after selecting the digitizing file. I
> found the statement that is causing the core dump, but I have no idea
> why the variable in question is NULL. The line of code that fails is
> line 312 of src/mapdev/v.digit/digmain.c:
> for (i = 0 ; M_edit.item[i].text != NULL ; i++)
> The reason it dumps core is that M_edit.item is NULL thus there is no
> elements in the array. However, I have no idea where this array is
> supposed to be initialized. This particular line of code has been in the
> file since grass was switched to CVS. Note that this particular piece of
> code is executed when there is no digitizer selected (ie digitize with
> the mouse) but we have been able to run v.digit before. The etc/digcap
> file seems to be fine as well.
> If anyone has any ideas or even confirmation that this bug exists on
> other systems, I would greatly appreciate hearing from you. This is
> rather urgent since we would like to start a digitizing project on
> Monday.
> Thank you in advance for any information you can provide.
> Sincerely,
> Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
> High Performance Computing Center
> National Electronics and Computer Technology Center (NECTEC)
> Bangkok, Thailand
> People who think they know everything are very irritating to those
> of us who do.  ---Anonymous
> Jazz and Trek Rule!!!
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
