[GRASS5] Re: [GRASSLIST:2065] Re: Compiling grass5.0.0pre1 under Solaris 8???
Markus Neteler
neteler at geog.uni-hannover.de
Fri Jul 6 10:22:30 EDT 2001
On Fri, Jul 06, 2001 at 05:45:10AM +0100, Glynn Clements wrote:
> [This started on GRASSLIST, but should be brought to the attention of
> the developers.]
> Lawrence Houston wrote:
> > > > Having troubles compiling grass5.0.0pre1 under Solaris 8 (Intel) using
> > > > SUN's Companion (04/01). LIBGIS fails within error.c:
> > > > gcc -g -O2 -I/opt/sfw/include -I/opt/grass5/grass5.0.0pre1/src/include -I/usr/include -c error.c -o OBJ.i386-pc-solaris2.8/error.o
> > > > error.c: In function `G_fatal_error':
> > > > error.c:72: `__builtin_va_alist' undeclared (first use in this function)
> > > > error.c:72: (Each undeclared identifier is reported only once
> > > > error.c:72: for each function it appears in.)
> > > > error.c: In function `G_warning':
> > > > error.c:87: `__builtin_va_alist' undeclared (first use in this function)
> > > > *** Error code 1
> > > > make: Fatal error: Command failed for target `OBJ.i386-pc-solaris2.8/error.o'
> > > Apparently this can occur when gcc tries to use vendor-supplied
> > > headers in preference to its own (typically in the directory
> > > /usr/lib/gcc-lib/<platform>/<version>/include).
> > > Try removing all occurrences of -I/usr/include from the file
> > > src/CMD/head/head.<platform>
> > Glynn:
> > Thanks very much since removing all occurrences of -I/usr/include from
> > head.i386-pc-solaris2.8 has done the trick, I now have grass5.0.0pre1
> > built under Solaris 8 (Intel)! There were also warnings about conflicts
> > between the System TERMLIB and NCURSES, although I those may NOT be
> > critical since full-screen cursor movement appears to "work"?
> > I thought using the gcc (2.95.2) included in SUN's Companion would be an
> > quick way to build GRASS under Solaris 8, did NOT anticipate conflicts
> > with the existing System "stuff"???
> It appears that the configure script needs to avoid using
> -I/usr/include when checking for header file locations.
> AFAIK, the compiler ought to search that directory automatically (and
> if it doesn't, the user should be able to use the "--with-includes="
> switch). It seems that explicitly adding -I/usr/include prevents
> compiler-specific headers (e.g. stdarg.h) from being used correctly.
> Currently, the header file checks loop over a list of directories
> (including /usr/include), performing each test with "-I$dir". Any such
> test needs to first be performed without any "-I" switch, rather than
> with "-I/usr/include".
> NB: my original advice was based upon comments made on the xemacs-beta
> list. That related to someone who explicitly added /usr/include via
> "--site-includes="; XEmacs' configure script (unlike GRASS') doesn't
> add "-I/usr/include" automatically.
> Looking at some configure.in scripts from other packages, most of them
> don't go to great lengths to find include directories automatically.
> Mostly they require the user to explicitly specify non-standard
> include directories.
Glynn,
I suggest to change the configure[.in] as suggested and give it a try.
I can test 3 machines here (Solaris, CRAY, Linux).
Will you going to change if there are no objections?
Markus
