[GRASS5] Monitor Resize Problem
Glynn Clements
glynn.clements at virgin.net
Thu Jul 19 11:00:22 EDT 2001
Bob Covill wrote:
> The above changes seem to work fine. Below is the HINTS output from
> xprops ...
> WM_NORMAL_HINTS(WM_SIZE_HINTS):
> program specified size: 450 by 400
> program specified minimum size: 0 by 0
> program specified maximum size: 1280 by 1024
> Maximising the window does seem to go a little bit larger than the
> screen size.
Damn. That implies that there's no simple way to get this feature to
work properly with everything. It will need to determine the size of
the WM "frame" in order to compute the correct maximum size (which
applies to the client window, not including the WM frame).
Glynn Clements <glynn.clements at virgin.net>
