[GRASS5] Monitor Resize Problem
Glynn Clements glynn.clements at virgin.net
Thu Jul 19 11:07:29 EDT 2001
Eric G. Miller wrote:
> > I guess the question is now,  is the problem unique to my particular
> > setup or will other Solaris dtwm machines have the same problem?
> Sounds like the same problem I reported having with the Blackbox window
> manager under Linux. Seems to work okay under several other window
> managers that I've tried (WindowMaker, AfterStep, IceWM).
Yeah, but this time it's dtwm, the "official" CDE WM.
I suspect that unless this bug has been acknowledged as such, and
fixed in a subsequent release, XDRIVER will *have* to work around it.
Glynn Clements <glynn.clements at virgin.net>
