[GRASS5] Darwin Pre1 gtty stty errors
Glynn Clements
glynn.clements at virgin.net
Mon Jun 4 21:21:02 EDT 2001
Jeshua Lacock wrote:
> I successfully installed the Darwin static c library (Libc), and I still
> get the gtty & stty errors. Apparently, gtty and stty have been made
> obsolete by ioctl().
> I quote Cornell's web page:
> "______
> These subroutines have been made obsolete by the ioctl subroutine.
> The stty subroutine sets the state of the terminal associated with the
> FileDescriptor parameter. The gtty subroutine retrieves the state of the
> terminal associated with FileDescriptor. To set the state of a terminal,
> the calling process must have write permission.
> Use of the stty subroutine is equivalent to the ioctl (FileDescriptor,
> TIOSETP, Buffer) subroutine, while use of the gtty subroutine is
> equivalent to the ioctl (FileDescriptor, TIOGETP, Buffer) subroutine.
> The complete URL is at:
> http://nim.cit.cornell.edu/usr/share/man/info/en_US/a_doc_lib/libs/basetrf2/
> stty.htm
> So should I try and replace the calls myself, or would someone be
> willing to help? An ideal simple test module that has this problem it
> d.colors.
The current implementation of d.colors uses the TCGETA/TCSETAW
ioctl()s if HAVE_TERMIO_H is defined and stty()/gtty() otherwise. If
you're getting errors regarding stty() or gtty(), then it appears that
configure hasn't detected the <termio.h> header.
However, the ioctl()s themselves have been superseded by the POSIX.1
tcgetattr() and tcsetattr() functions.
A more significant "however" is that d.colors/tty.c is redundant; the
only functions which are used are Get_old_tty() and Get_new_tty().
These store the terminal settings before and after curses
initialisation. But the stored settings are never used, i.e. neither
Old_tty() nor New_tty() are called.
I will commit a fix which removes this code, which should eliminate
any portability considerations altogether. If you know of any other
programs which do this, let me know.
Glynn Clements <glynn.clements at virgin.net>
