[GRASS5] Darwin Pre1 NVIZ
Eric G. Miller
egm2 at jps.net
Tue Jun 5 22:40:15 EDT 2001
On Wed, Jun 06, 2001 at 02:01:47AM +0100, Glynn Clements wrote:
> Are you actually using r3.showdspf.openGL (from GMSL/g3d)? AFAIK, this
> is the only program which actually requires libGLwM. As it currently
> has outstanding bugs, it isn't in the 5.0.0 release branch in CVS.
> Also, its documentation specifically refers to using Mesa's libGLw
> (from the widgets-sgi directory) rather than libMesaGLwM (from
> widgets-mesa).
> I don't want to change configure to accept libMesaGLwM in place of
> libGLwM unless it's known to work.
> If GMSL/g3d isn't going to make it into the release, we may as well
> just remove the GLw checks altogether; otherwise they just confuse
> people.
I might add, the widgets should have appropriate symlinks. Like:
libGLwM.a --> libMesaGLwM.a
But I wouldn't recommend using the 3d grid stuff anyway (big bugs!).
Eric G. Miller <egm2 at jps.net>
