[GRASS5] display
Mior Mohd Hadafi mhadafi at yahoo.com
Wed Jun 6 13:06:35 EDT 2001
dear grass user,
i'm new to using grass, i was using linux red hat 7.0
as an OS. now i have some problem to start the display
monitor (x0, x1, x2... x6, CELL, HTMLMAP) i try to
refer all manual which i have and from the internet
then follow the instruction but it was not happend....
the problem is when i give command to start the
monitor (x0) the monitor cannot be start and give the
message:
Sorry, </usr/local/grass5/dev/fifo.1a> not available
Have GRASS administrator check etc/monitorcap file
Can't stat /usr/local/grass5/dev/fifo.1a
Problem selecting x0. Will try once more
i was login as user to run this grass program.
thank you
best ragard
mior
__________________________________________________
Do You Yahoo!?
Get personalized email addresses from Yahoo! Mail - only $35
a year!  http://personal.mail.yahoo.com/
