[GRASS5] Darwin Pre1 gtty stty errors
Eric G. Miller egm2 at jps.net
Wed Jun 6 21:43:43 EDT 2001
On Wed, Jun 06, 2001 at 09:00:18AM +0100, Glynn Clements wrote:
> Eric G. Miller wrote:
> > The dtd is not copied to "etc" though it should be (or share/xml ??).
> > I was just playing with this the other day to parse the output from
> > hitting each command with the "--interface-description" flag.
> > Unfortunately, some modules (and shell scripts), do things before
> > calling G_parser() that muck this up.
> Do you have any specific cases? That sort of thing should probably be
> fixed for 5.0.0.
You asked for it (note, I don't have any of src.garden compiled...)
d.colors
d.colortable
d.db
d.display
d.geodesic
d.icons
d.label
d.labels
d.legend
d.leg.thin
d.measure
d.menu
d.pan
d.points
d.rast.edit
d.save
d.scale
d.sites
d.sites.qual
d.text
d.title
d.what.rast
d.what.sites
d.what.vect
d.zoom
g.access
g.help
g.setproj
g.version
i.class
i.colors
i.composite
i.group
i.ortho.photo
i.points
i.points3
i.quantize
i.rectify
i.tape.mss
i.tape.other
i.tape.spot
i.tape.tm
i.target
i.vpoints
m.examine.tape
m.futil
m.in.stf1.tape
m.lulc.USGS
m.proj
p.chart
p.colors
p.icons
p.labels
r.agnps50.run
r.agnps50.view
r.digit
r.mapcalc
r.mask
r.reclass.scs
r.water.fea
r.weight
tcltkgrass
v.digit
v.export
v.import
v.in.tig.basic
v.in.tig.lndmk
v.out.mapinfo
v.out.moss
v.patch.scs
v.sdts.meta
Eric G. Miller <egm2 at jps.net>
