[GRASS5] Buffer overflow in G_recreate_command()...
Glynn Clements
glynn.clements at virgin.net
Thu Jun 7 01:52:01 EDT 2001
Glynn Clements wrote:
> > I don't know that the buffer needs to be bigger, but maybe. With the
> > PAD_LIST, it appears the data eventually gets put in dynamic memory
> > anyway. One possibility would be to add a "SIZE" argument to the text
> > commands so the read commands would know exactly how much space to
> > allocate and if the "transaction" was complete. Other possibility is to
> > make the buffer "ARG_MAX" + 1 size, though that may be a little greedy
> > (around 13.5k here...).
> ARG_MAX is 128kb on Linux 2.4; even greedier. Stevens implies that
> sysconf(_SC_ARG_MAX) is 1Mb on SunOS 4.1.1, although it doesn't say
> whether the ARG_MAX macro is the same. Ultimately I don't think that
> anything actually imposes an upper limit on what ARG_MAX might be.
> As RECTEXT() is only ever used on two variables ("name" and "text"),
> I'll change it to dynamically (re)allocate the memory.
OK; this is done. There shouldn't be any limitation now.
Glynn Clements <glynn.clements at virgin.net>
