[GRASS5] Curiuos problem
Markus Neteler neteler at geog.uni-hannover.de
Tue Jun 12 04:17:14 EDT 2001
Robert,
On Mon, Jun 11, 2001 at 12:45:41PM -0400, Robert Lagacé wrote:
> This morning, we started experimenting with v.digit through tcltkgrass.
> We created two new maps "dtest_1" and "digit_test" with few lines, one area
> and two sites.  We converted them with v.ascii and made topology with
> v.support.
> The problem is that we cannot find the files anywhere in the mapset
> using file commands (ls) and (find).  Grass modules (v.display, v.ascii,
> v.support) in tcltk grass see them.  The ls and find command see all others
> maps that GRASS see except the ones created with v.digit.  These files
> should be in "dig" and "dig_ascii" and "dig_plus" directory.
> Where could be saved??
this is quite strange, here it runs well. Perhaps you are working
in different mapsets?
> V.digit show avery small problem : window terminal does not repaint when
> we resize it.  It repaint without problem when exposing it.
This was already fixed in CVS by Glynn: v.digit now freezes the monitor size
to avoid such confusions. After leaving v.digit it can be resized again.
Regards
 Markus
