[GRASS5] compilation HP-UX
Robert Lagacé
lagace at grr.ulaval.ca
Wed Jun 13 19:13:48 EDT 2001
"Eric G. Miller" wrote:
> On Wed, May 30, 2001 at 06:35:06PM -0400, Robert Lagacé wrote:
> > I cimpiled succesfully GRASS on HP-UX except a few modules that I will
> > talk about later on.
> [snip]
> > - d.area with the following message
> > gcc -g -O2 -I/opt/libpng/include -I/local/grass5.0.0pre1/src/include
> > -c plot.c -o OBJ.hppa1.1-hp-hpux10.20/plot.o
> > In file included from plot.c:18:
> > screenpoly.h:39: warning: redefinition of `uint8_t'
> > /usr/include/sys/_inttypes.h:62: warning: `uint8_t' previously declared here
> > screenpoly.h:42: conflicting types for `uint32_t'
> > /usr/include/sys/_inttypes.h:66: previous declaration of `uint32_t'
> > *** Erreur - code de sortie 1
> Dang, I tried to guard for that. "screenpoly.h" is the last include for
> plot.c and has...
> #if !defined(uint8_t)
> typedef unsigned char uint8_t;
> #endif
> #if !defined(uint32_t)
> typedef unsigned long uint32_t;
> #endif
> But maybe those aren't working? d.area is fairly broken anyway -- Anyone else
> want to take a crack at it?
> Eric G. Miller <egm2 at jps.net>
> grass5 mailing list
> grass5 at geog.uni-hannover.de
> http://www.geog.uni-hannover.de/mailman/listinfo/grass5
I successfully compile d.area with the following change in in screenpoly.h
(wrapping the #if !defined code)
#ifndef __INTTYPES_INCLUDED
#endif
#endif
#endif
uint8_t and uint32_t are defined in /usr/include/sys/_inttypes.h where they
are defined under __INTTYPES_INCLUDED the following way
typedef unsigned char uint8_t; /* 8-bit unsigned integer */
typedef unsigned int uint32_t; /* 32-bit unsigned integer */
So as uint32_t should be defined typedef unsigned int uint32_t as suggested.
I do not know by which include file _inttypes.h is pick up.
This solution may work on other systems.
d.area run displaying areas and borders but without area or perimeter
information.
But the module v.area do that.
Robert Lagacé, professeur
Pavillon Comtois
Université Laval
Ste-Foy, Québec, G1K 7P4
tel : (418)-656-2131#2276
Fax : (418)-656-3723
E-mail : lagace at grr.ulaval.ca
