[GRASS5] grass font
Rich Shepard
rshepard at appl-ecosys.com
Fri Jun 15 09:58:56 EDT 2001
On Fri, 15 Jun 2001, Radim Blazek wrote:
> - Labels (texts in map) must be identical (realy identical - the same font
> fonts with the same metrics) in:
> - XDRIVER
> - CELL, PNG, (and similar) drivers
> - Postscript files created by ps.map
> - all new possible clients/viewers: java, windows (not CygWin+Xfree)
> Is it possible to display (effectively) exactly the same fonts on many
> platforms? Probably not. Where could we learn from - Acrobat , Ghostscript?)
> - System fonts in some standard format should be used. Fonts should not be
> distributed in grass package.
> - Vector fonts should be used.
I will put in a vote for Type1 postscript fonts. I cannot address the
issue of i18n here, but at least in the western hemisphere and western
Europe, it is possible to get the same typefaces/fonts in both Type1 and
TrueType (for the Windows crowd).
Also, I recommend that when this part of the software is revamped that it
make use of the fonts available on the system rather than being limited to
whatever is built in; for example, in /usr/X11R6/lib/X11/fonts. If I'm not
mistaken, this is what most applications do. It would certainly make GRASS a
bit smaller, lighter and easier to maintain.
Rich
Dr. Richard B. Shepard, President
Applied Ecosystem Services, Inc. (TM)
2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard at appl-ecosys.com
Making environmentally-resposible mining happen.
