[GRASS5] [bug #755] (grass) help (again)
Request Tracker
grass-bugs at intevation.de
Fri Jun 15 17:49:11 EDT 2001
this bug's URL: http://intevation.de/rt/webrt?serial_num=755
Hi people,
Thank you for the fast answer. I am a biologist working in a
biodiversity survey in Brazil. At this moment I am evaluating the
possibility of using a GIS software to analyse our data (insects and their
host plants distributed in a macrogeographic scale). As I am a first time
GRASS GIS user, I would like to know if there is any kind of "step-by-step
tutorial" available.
Do you think I would have advantages using GRASS GIS
or you recommend a simpler software (as ArcView)?
I got GRASS4.3 and installed it succesfully, but I failed in loading
SPEARFISH database - after informing location, mapstets, etc I received
messages like:
ENC: unbound variable
XIM:unbound variable
etc
I also would like to know where do I find the information to set up a new
location???
I also got GRASS5 and installed it, but when I try to start with the
command "grass5", the answer is a message "Starting grass" and a new blank
window (gis_set.tcl) that appears -- and anything else happens.
Thank you very much for you patience...
--- Headers Follow ---
>From rafael at unicamp.br Fri Jun 15 23:49:11 2001
Return-Path: <rafael at unicamp.br>
Delivered-To: grass-bugs at mailman.intevation.de
Received: from omecihuatl.rz.uni-osnabrueck.de (omecihuatl.rz.Uni-Osnabrueck.DE [131.173.17.35])
by mailman.intevation.de (Postfix) with ESMTP id 09834139F0
for <grass-bugs at intevation.de>; Fri, 15 Jun 2001 23:49:11 +0200 (CEST)
Received: from obelix.unicamp.br (obelix.unicamp.br [143.106.10.2])
by omecihuatl.rz.uni-osnabrueck.de (8.11.1/8.11.1) with ESMTP id f5FLlq121575
for <grass-bugs at intevation.de>; Fri, 15 Jun 2001 23:47:53 +0200
Received: by obelix.unicamp.br (Postfix, from userid 42221)
id 922D227BF6; Fri, 15 Jun 2001 18:48:08 -0300 (BRT)
Received: from localhost (localhost [127.0.0.1])
by obelix.unicamp.br (Postfix) with ESMTP
id 78FE121C2A; Fri, 15 Jun 2001 18:48:08 -0300 (BRT)
Date: Fri, 15 Jun 2001 18:48:08 -0300 (BRT)
From: =?X-UNKNOWN?Q?Rafael_Lu=EDs_Galdini_Raimundo_-__#071100000000?= =?X-UNKNOWN?Q?00#_?= <rafael at unicamp.br>
To: Markus Neteler via RT <grass-bugs at intevation.de>
Cc: neteler at geog.uni-hannover.de
Subject: help (again)
In-Reply-To: <20010615155326.DF28B139F4 at mailman.intevation.de>
Message-ID: <Pine.GSO.4.10.10106151758560.21605-100000 at obelix.unicamp.br>
MIME-Version: 1.0
Content-Type: TEXT/PLAIN; charset=US-ASCII
-------------------------------------------- Managed by Request Tracker
