[GRASS5] [bug #755] (grass) help (again)
Justin Hickey via RT grass-bugs at intevation.de
Mon Jun 18 05:16:33 EDT 2001
Hi
rafael at unicamp.br wrote (Fri, Jun 15 2001 23:49:11):
> I also got GRASS5 and installed it, but when I try to start with the
> command "grass5", the answer is a message "Starting grass" and a new blank
> window (gis_set.tcl) that  appears -- and anything else happens.
Sorry I can't help ypu with your GRASS 4.3 problem but for GRASS 5 delete the
file $HOME/.grassrc5 and then run grass5 again. This should solve the above
problem.
Justin Hickey
-------------------------------------------- Managed by Request Tracker
