[GRASS5] 0 != no data
Moritz Lennert
mlennert at club.worldonline.be
Tue Jun 19 05:48:12 EDT 2001
Hello Justin, hello all,
Shouldn't there be an introductory phrase reminding people what this NULL
business is all about ? I would imagine some users out there might not fully
understand what we're talking about.
Moritz
Quoting Justin Hickey <jhickey at hpcc.nectec.or.th>:
> Hello all
> Sorry for the late reply, but I had other matters to take care of. As
> per Markus' suggestions, some text has been changed in the post I
> recommend we send to users. Please take a moment to review the post
> below.
> Markus Neteler wrote:
> > thanks for your nice proposal. A few remarks:
> > - Perhaps (even for the new users), an example may be added to
> > demonstrate the 0 to be NULL thing
> I'm not sure what you mean here. What kind of example are you thinking
> of, a classification example?
> > - it should be pointed out, that GRASS 5 will keep the feature to
> > store NULLs (for those not carefully ready), perhaps in a bottom
> > summary
> > convert individual values to NULL and back
> > - maybe in a bottom summary it should be explained, that, if
> > eliminating the feature of 0 to be NULL, that both groups (1) and
> > (2) will stay happy, only that a conversion step is required (or
> > not?).
> OK I've made some changes, see the example post below.
> > BTW: Does anyone know a free poll server without adult images or
> > annoying ads? I don't want that they catch all the users' email
> > adresses and sell them anywhere.
> Sorry I can't help you here, but we could simply have them reply to the
> message or send their votes to me if we can't find a suitable poll
> site.
> ======================== Start of post ===============================
> Subject: We need your opinion
> Hello all users
> Recently on the developers mailing list, there has been a discussion
> concerning the current implementation of NULL. When the NULL concept
> was
> first introduced and implemented there were basically 2 groups of
> users:
> 1. Those who worked mostly with classes and had a large number of
> files with 0 set as NULL
> 2. Those who started to use raster maps as representation of
> continuous fields and 0 was a data value
> The majority of the users were in group 1 and thus, the decision was
> made to keep the feature that 0 could be interpreted as NULL.
> In the discussion on the developers list, some developers have
> indicated
> that since GRASS 5.0 has the concept of NULL (which is represented by
> non-zero values), it is confusing to also have the feature that 0 can
> be
> interpreted as NULL, especially to new users of GRASS. This feature has
> also caused some problems for some users who had greyscale aerial
> photographs stored as raster maps in GRASS 4.x, and then transferred
> them to GRASS 5.0. The problem was that the color black (value 0) was
> being interpreted as NULL causing them to believe that their data had
> been corrupted somehow.
> In order to eliminate this confusion, a proposal was put forth on the
> list that 0 should never be considered as NULL in GRASS 5.0. Also, in
> order to facilitate those users who wish to use their GRASS 4.x files
> with the new GRASS 5.0, we would provide a script to assist them in
> converting the 0 values of their data to appropriate NULL values in
> GRASS 5.0.
> This script has not been written yet but the proposed usage would be
> that a user would run the script and provide a list of GRASS 4.x
> databases which contain raster files in which 0 should be interpreted
> as
> NULL. The script will automatically go through all locations and
> mapsets
> in each database and perform the conversion for all raster files. The
> only requirement for this script would be that the GRASS 4.x data would
> have to be maintained in proper GRASS databases. That is, all
> directories under a database will be locations, and all directories
> under a location will be mapsets. If a user has files that he/she does
> not want converted then either the files can be moved to a different
> database, or the user can provide a specific location, or mapset, or
> raster file to the script.
> In summary, the proposal is to remove the feature of 0 being
> interpreted
> as NULL from GRASS 5.0. It is important to remember that GRASS 5.0 will
> store well defined NULL values (non-zero) and that GRASS 5.0 will
> provide the capability to convert any value to NULL or vice versa. Note
> that the elimination of this feature will satisfy both groups of users
> since both NULL values and 0 will be available to users. The only
> consequence of this removal is that a conversion process will be
> necessary for converting GRASS 4.x data into GRASS 5.0 data.
> What we would like you to do is provide us with your opinion on whether
> we should keep the feature of 0 being interpreted as NULL. To make
> things a little easier, we would like you to reply to this post stating
> which of the following options (a or b) you wish to support.
> a) Keep the feature of 0 being optionally interpreted as NULL in
> GRASS 5.0
> b) Eliminate the feature from GRASS 5.0, but a script will be
> provided to convert GRASS 4.x files to GRASS 5.0 format for
> those who wish 0 to be NULL
> Thank you for your time in this matter.
> ========================= End of post ================================
> Once again, any comments in the wording of the above post are welcome.
> Sincerely,
> Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
> High Performance Computing Center
> National Electronics and Computer Technology Center (NECTEC)
> Bangkok, Thailand
> People who think they know everything are very irritating to those
> of us who do. ---Anonymous
> Jazz and Trek Rule!!!
> grass5 mailing list
> grass5 at geog.uni-hannover.de
> http://www.geog.uni-hannover.de/mailman/listinfo/grass5
This mail sent through Tiscalinet Webmail (http://webmail.tiscalinet.be)
