[GRASS5] broken links in documentation and s.vol.rst
Markus Neteler neteler at geog.uni-hannover.de
Thu Jun 21 06:08:44 EDT 2001
On Thu, Jun 21, 2001 at 12:45:59AM -0700, Eric G. Miller wrote:
> On Thu, Jun 21, 2001 at 08:34:21AM +0100, Markus Neteler wrote:
> > Hi Eric,
> > it would be perfect to update them in CVS (only?):
> > html/grass_commandlist.html
> > Then it appears on the web automagically.
> Ahh, I see you have the index linking into the man page directory.  Did
> a little search and replace on the href's?  I'll try to update it
> tomorrow then (must sleep).
Yes, please adjust the direct urls to the modules by
html/<module>
Then upload and everyone will get happy :-)
> Been playing with XSL transformations, and they could really work out
> nicely (once I figure out all the syntax). Should be easier to write the
> transformation stylesheet to produce xhtml than to code up a complicated
> program that'd break anytime the structure of the XML was changed
> slightly (well, so would the XSL, but it should be much easier to
> update).  Figure if I can get the syntax worked out, we'd only need a
> little shell script to call "xsltproc" (part of libxslt).  Well, more on
> this later...
Sounds good...
Sleep well!
 Markus
