[GRASS5] display bitmap
Glynn Clements
glynn.clements at virgin.net
Sat Jun 23 12:34:07 EDT 2001
Somesh Agarwal wrote:
> I have a bit map and position from which I must display it and
> the coordinates of the window in which it should be displayed.
> Now how do i display it on the X device or PNG driver .
Are you looking for commands or functions?
At the command level, use d.frame then d.rast.
At the function level, either use R_reset_color() then R_raster(), or
use the D_draw_* functions.
Glynn Clements <glynn.clements at virgin.net>
