[GRASS5] Interfaces ... (long)
Eric G. Miller
egm2 at jps.net
Thu Jun 28 02:41:26 EDT 2001
As some of you may know, I've been monkeying around with the XML
interface thing that Jan put together (thanks Glynn for fixing that
printf bug). Anyway, I have some changes or proposals I'd like to
submit. I've categorised them in order of importance and ease of
implementation. I apologize if I've made some assumptions about
SGML/XML knowledge.
Simple and Necessary:
* Currently the "gisprompt" and "key_desc" parts of the Option
group are ignored. Both are very important for providing a user
with the correct interface. I submit that these changes should be
added as attributes of the "parameter" element right away.
* There needs to be a way to handle interactive programs. I'll have
more on this later, but perhaps there should be an attribute of
"task" for flagging interactive *only* programs. Some programs
may run as command line, but prompt for user input. This latter
case is more difficult, but for the time being they could all be
specified as "interactive" and a front-end that couldn't accomodate
that could drop the "task" from its list. TclTkGrass has a
mechanism to spawn an xterm for these, but that wouldn't be viable
for a browser interface... For the simple yes/no interactive, this
could be added to the GModule struct (name, description,
interactive?).
Simple and better semantics:
* Currently the "parameter" element is used both for Options and
Flags. From a parsing stand point, it makes life slightly more
difficult. Also, most of the attributes and child elements of the
"parameter" element do not apply to Flags and would be erroneous if
present (e.g. "required=", "multiple=", "<default>",
"<values>,<value>"). A flag is always "off" by default, and is
almost never required (more on this later), can't be specified
multiple times, and has no set of possible values.
I propose separating the flag element from the parameter element.
<!ELEMENT flag description?>
<!ATTLIST flag name CDATA #REQUIRED>
<!ELEMENT parameter-group (description?, (parameter | flag)+)>
* Currently the DTD does not enforce that if there is a "default"
element and a set of "value" elements, that the default be a
member of the set of "values". It may be better to have an
attribute of "value" that has default property, or to let
"default" occur once in the "values" set. The latter is probably
easier and more logically correct. NOTE: DTD's can't really say
much about the content of elements, only the structure (XML
Schemas *can* speak to content, but it is only recently adopted).
But the G_usage_xml() could clearly handle the latter case, and
it'd help any front end. This change is less important, but a
good idea IMHO.
More Work and More Complex:
* In some modules there is a clear dependency/conflict relationship
between various flags and options. In cases I've encountered, it
often seems to be, you can run the command with a, b, c or with a
and d (but not b and c). I think it would be valuable to be able
to capture this inter option/flag dependency, as better interfaces
could be generated. I don't have a fully formulated suggestion
for this one, but it would require some significant changes.
One way to look at them, is to create an option/flag grouping.
This should be feasible within the current DTD framework as more
than one "parameter-group" can exist for a given task. However,
the "parameter-group" is probably too high up the chain, as we
would probably not want to have to duplicate common options for
each parameter-group.
One way to change this in the DTD, would be to allow "parameter"
and "flag" elements to exist as direct children of "task" and only
use "parameter-group" when a set of options should be grouped
together *and* conflict with any other parameter-group. The
G_parser() system would have to have a way to specify this
information. There could be the concept of a OptionGroup, and
individual options could be added to OptionGroups.
Another way to approach, might be to add a mechanism to specify
more complex dependency/conflict relationships between options
before calling G_parser(). That is there'd be a functions like:
G_parser_depends (OptionOfInterest, OptionRequired),
G_parser_conflicts (OptionOfInterest, OptionConflicts)
There'd be some interaction with the "required" member for Options
which would need to be considered. For instance, if a "global"
option has "opt->required = YES", then another option can't
conflict with it. Nor, could one option require an option that
requires a third option that conflicts with the first. I'm not
sure how you'd specify this in a DTD...
This kind of dependency/conflict stuff can't get a bit hairy, but
it would provide the ability to create better user interfaces.
Pipe Dream:
* Returning to the problem of interactive programs...
This gets alot deeper into system architecture concepts, but it is
extremely important if we agree there should be a mechanism for
separating the interface from the implementation.
It's clear there needs to be a mechanism for a running module to
prompt for user action, but be able to do so in a way not tied to
any particular implementation (like Vask or the various G_ask_*
listing routines both which assume a terminal, and the first
assumes "curses"). We could return to XML to provide such
mechanisms (or at least the specifications), but it will take some
thought and alot of work to realize.
There are different types of user interaction that are often
required. The simplest to deal with would probably be the Vask
case where the user is prompted to fill out "form" type data.
But, the program would have to know it wants to dump out a form
specification, rather than a curses interface *and* the program
would have to have to ability to restart where it left off
(consider the nature of http -- the module would have to exit,
then be restarted when it was called again with the form data
"posted").
Even if we solved the above, what about display programs that take
direction via "mouse clicks", or something of the nature of
v.digit? Here the interaction is of a different sort, and it
wouldn't do for the modules to stop and start.
I don't have much for suggestions on this last one, but it is
something to consider longer range.
Eric G. Miller <egm2 at jps.net>
