[GRASS5] v.trim (RC bug)
Markus Neteler neteler at geog.uni-hannover.de
Fri Mar 30 04:41:19 EST 2001
Hi Andrea,
On Wed, Mar 28, 2001 at 08:13:43AM +0200, Andrea Aime wrote:
> Hi Markus, hi everybody,
> last night I tried to track down v.trim bug that has been marked as
> release critical... well, my opionion in short is that v.trim has
> too many bugs and to make it useful it needs a major rewrite, not a
> bug fix. Well, now a more in depth description to support my opinion.
> v.trim is expected to remove small spurs and node in excess from a
> vector
> layer based on a trimming factor that is the minimum distance between
> nodes
> (beware, I said nodes, not vertices, I mean line endings). Here the list
> of bugs I've seen in that small program (277 lines of code):
> * trim factor is just a distance (a double), not a percentage, so why
>   limit it between 0 and 100?
> * a line is eliminated if the euclidean distance between its nodes
>   (line endings) is less than the trimming factor... no surprise that
>   closed loops gets eliminated, start node = end node, so euclidean
>   distance is 0 regardless of how big is the loop;
> * two consequent lines are joined into one regardless of their
> attributes
>   -> this is loss of information
> * in fact attributes are not treated at all, the output file loses all
>   the label points
> There are also other problems, but it seems to me that the ones cited
> are enough (for me) to vote for v.trim removal from grass 5 stable:
> fixing it is almost equivalent to building it from scratch,
> it seems much more a new feature than a bug fix :-). What is your
> opinion?
Yes, I have comment it in the compile list.
> BTW, we still have to take a decision about zero handling in vector
> files...
If you have a preferred way for r.poly, please implement it. We have
to speed up for 5.0 now, otherwise noone will believe in it any more.
As vector section completely changes, we simply need a "rather" working
r.poly.
Thanks for analysing v.trim!
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
