[GRASS5] why GPL
Malcolm Blue mblue at nb.sympatico.ca
Tue Mar 27 02:19:16 EST 2001
strobe anarkhos wrote:
> At 12:04 PM +0700 3/27/01, Justin Hickey wrote:
>> Hi Strobe
>> I'm not going to comment much on the main arguments so far, however, I
>> feel I need to clarify a point about the protection offered by the LGPL
>> and the GPL. Note that I'm not a lawyer and the only parts of these
>> licenses I read were the preambles.
> FSF preambles are political rhetoric. I'm only concerned over the legality, which by the way hasn't changed since it was called the 'Library' GPL.
You didn't respond to his question.  This was his preamble to his
question (keep reading).  If you can't answer the question then say so.
Several others have already questioned your interpretation of the
legality.  I think he and several others have also questioned your
understanding of the different licenses and the reasons people have
chosen to go with the GPL.
If you don't want to license your software under the GPL that's your
choice.  I still haven't seen any real reasoning in your replies to
strainght forward questions.  Dismissing information as "political
rhetoric"  and adding pointless filler statements as above are a waste
of bandwidth.
If you have anything to say, then say it!
Otherwise listen.
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
