[GRASS5] Add libgdal to configure?
Eric G. Miller
egm2 at jps.net
Fri Mar 23 03:23:08 EST 2001
On Fri, Mar 23, 2001 at 02:37:34PM +0700, Justin Hickey wrote:
> Hello all
> I was just thinking that we should add a check for libgdal to configure
> and provide a --with-gdal=DIR option. What do people think? I don't know
> exactly how this would work or whether there would have to be changes
> made to r.in.gdal, but it seems that configure is where we should
> determine if libgdal is installed. Is this feasible?
It's probably a good idea. It requires a little hackery to get the
build system to turn things on/off though.
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
