[GRASS5] Re: Problem running NVIZ
Markus Neteler
neteler at geog.uni-hannover.de
Thu Mar 22 13:27:35 EST 2001
Hi Steve,
(cc to grass5)
currently I am sorry - no idea! Probably the nviz as being build
on Suse7 conflicts with Mandrake 7.2.
Hi all, it seems we furtherly have to investigate the
BUG IN DYNAMIC LINKER ld.so...
problem (see below). Steve does *not* have libstdc++ locally in
$GISBASE/lib/, so this idea didn't help.
Any comments are welcome,
Markus
On Thu, Mar 22, 2001 at 10:47:51AM -0700, Stephen Griffiths wrote:
> Hi Markus,
> Well, I was wrong. It turns out that Mesa is installed. Version 3.3-14mdk (OpenGL 1.2
> ). Still no luck running nviz.
> Steve
> Markus Neteler wrote:
> > On Thu, Mar 22, 2001 at 09:56:53AM -0700, Stephen Griffiths wrote:
> > > Hi Markus,
> > > My system is as follows:
> > > AMD 1100Mhz running Mandrake 7.2, 128Mb ram, 30Gb hard drive, 128 bit ATI fury
> > > pro graphics card.
> > > I used "grass5_0beta11_2_Linux_bin.tar.gz" and "grass5install.sh" to install it
> > > into "/usr/local/grass5".
> > > Do I need to install "Mesa-3_2-2_i386.rpm" for the graphics engine? Currently it
> > > is not installed (I dont think).
> > Yes, this one is needed. Please report again then.
> > Markus
> > > > > > > Hi all,
> > > > > > > I have been having a problem running nviz. I have Grass 5 beta 11
> > > > > > > installed
> > > > > > > on an AMD 1100Mhz running Mandrake 7.2, and all seems fine except for
> > > > > > > running
> > > > > > > nviz. When I try I get the following error message:
> > > > > > > BUG IN DYNAMIC LINKER ld.so: dl-version.c: 210: _dl_check_map_versions:
> > > > > > > Assertion `needed != ((void *)0)' failed!
> > > > > > > Anyone have anuy ideas?
> > > > > > > Thanks......
> > > > > > > Steve
> > > > > > Markus Neteler * University of Hannover
> > > > > > Institute of Physical Geography and Landscape Ecology
> > > > > > Schneiderberg 50 * D-30167 Hannover * Germany
> > > > > > Tel: ++49-(0)511-762-4494 Fax: -3984
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
