[GRASS5] r.contour update
Andrea Aime
aaime at comune.modena.it
Mon Mar 12 02:53:09 EST 2001
Hi everybody,
yesterday Markus has commited a bug fix and
enhancement version of r.contour that I have hacked during the weekend.
What's new:
* category support bug has been fixed: r.contour2 produces also
dig_cats file, so d.what.vect no more complain about missing
category support. Since a contour level could be floatig point
I've inserted in the label the true value, whilst category number
remains its integer equivalent ( ===> so there may be problems if
one asks for fp contour levels that match the same integer number, I
haven't tested that case);
* a little trick (derived from GMT contour program) avoids some
kind of backtrack (well, I was thinking any kind of backtrack, but
Justin showed me that I was wrong :-) : data matrix is parsed,
and if a cell whose data matches exactly
a contour value its value is added a small quantity (the smaller
one that makes cell[i] + small != cell[i], I've taken into
consideration double encoding).
* one can specify a minimum number of point for a contour line to
be put into outout, so that small spurs, single points and so
on won't be present and the output will be more clear (that's
optional anyway);
* in my opinion there were minor memory handling problems in
r.contour, I've corrected them (Head.map_name was not guaranteed
to be properly terminated, Points structures in contour function
were not deallocated).
Markus has corrected some remaining bugs as well.
Bye
Andrea Aime
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
