[GRASS5] Problem with sockets on Linux
Eric G. Miller
egm2 at jps.net
Thu Mar 8 21:40:28 EST 2001
On Thu, Mar 08, 2001 at 09:36:13AM +0000, Markus Neteler wrote:
> On Thu, Mar 08, 2001 at 09:00:37AM +0100, Andrea Aime wrote:
> > I've tried make distclean, but without success, I always get the
> > same error. Before "make distclean" I also deleted my installation
> > directory and my .grassrc5. Please note that I install with a different
> > prefix (that should not make any difference, but I don't understand
> > where the error is). Any other ideas? Some way to get more detailed
> > error logs?
> > Bye
> > Andrea
> To confirm: The same problem occurs on SUN/Solaris. No effect with
> make distclean and a complete re-compile (I tried twice). There must
> be a recent bug... (another reason to clean out the unused driver stuff).
Is the server running (or did it exit)? (try "ps aux | grep <driver>").
Does following with a "d.mon select=<DRIVER>" succeed? (the timing
issue...).
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
