v.out.xfig (was: Re: [GRASS5] wrapper for awk?)
mlennert at ulb.ac.be
Wed Mar 7 08:28:30 EST 2001
neteler at geog.uni-hannover.de said:
> Moritz, could you try?
> cvs up src/scripts/contrib/v.xfig
> v.out.xfig v.in.xfig
I have no v.in.xfig in the v.xfig directory, but v.out.xfig works with awk
being in /usr/bin/awk.
I still have the problem that some of the files are not readable at all by xfig. If I see the pattern correctly it seems to be because v.out.xfig writes the coordinates in exponential format (7.67352e+11 4.57982e+11). Since xfig fails in those lines, I suppose that must be the problem.
I also have a file (with "normal" coordinates) where I get no error message and I can see the content of the file (circles made with v.bubble) in the preview window of xfig's file open window, but I don't see anything anymore once I open the file. I've tried zooming in and out to the max, but haven't found anything.
I created a test x-y location, 10x10, with three objects. The ascii vector file contains:
ORGANIZATION: USDA Nat. Res. Cons. Serv.
DIGIT DATE:
DIGIT NAME:
MAP NAME:
MAP DATE:
MAP SCALE: 1
OTHER INFO:
ZONE: 0
WEST EDGE: 0
EAST EDGE: 10
SOUTH EDGE: 0
NORTH EDGE: 10
MAP THRESH: 0
VERTI:
A 4
7.06867672 4.38860972
4.43886097 7.38693467
4.48911223 2.54606365
7.06867672 4.3718593
A 5
3.70184255 3.14907873
3.70184255 6.18090452
1.62479062 6.1641541
1.6080402 3.06532663
3.70184255 3.11557789
A 4
4.50586265 3.04857621
4.42211055 6.19765494
3.68509213 6.14740369
The file that results from v.out.xfig contains:
#FIG 3.2
Landscape
Center
Metric
A4
100.00
Single
-2
1200 2
4 0 0 100 0 0 12 0. 4 0 0 236 436 SCALE=1 W=0 E=10 S=0 N=10 \001
2 1 0 1 1 3 100 0 20 0.000 0 0 -1 0 0 4
207572 138723
349225 262967
120522 260593
206780 138723
2 1 0 1 1 3 100 0 20 0.000 0 0 -1 0 0 5
149011 297786
292247 297786
291456 395915
145054 396706
147428 297786
147428 297786
144263 259801
293038 263758
290664 298578
i.e. the coordinates are much higher. I can see this drawing by zooming out very far, but is this normal behavior ?
Moritz
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
