[GRASS5] XEXTRALIBS and -lsocket
Justin Hickey
jhickey at hpcc.nectec.or.th
Wed Mar 7 05:13:25 EST 2001
Hi Markus
Markus Neteler wrote:
> Macro: AC_PATH_XTRA
> An enhanced version of AC_PATH_X. It adds the C compiler flags
> that X needs to output variable X_CFLAGS, and the X linker
> flags to X_LIBS. If X is not available, adds'-DX_DISPLAY_MISSING'
> to X_CFLAGS.
> This macro also checks for special libraries that some systems
> need in order to compile X programs. It adds any that the system
> needs to output variable X_EXTRA_LIBS. And it checks for special
> X11R6 libraries that need to be linked with before
> '-lX11', and adds any found to the output variable X_PRE_LIBS.
> It seems to be related to X_EXTRA_LIBS or not?
Hmmm. This is interesting. This means that on Solaris, X_EXTRA_LIBS has
always been defined as -lsocket -lnsl. Now, the d.* commands are not
linking with the new socket code, which means that they require a
-lsocket to link. The question is do we use the X_EXTRA_LIBS variable to
add this to the d.* commands? I would say no since the d.* commands
didn't need the X_EXTRA_LIBS before the socket code. Thus, I still
recommend that we create a new make variable for -lsocket. Anyway,
that's just my opinion.
However, I just saw you added it to XDRLIB.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
