[GRASS5] grass cvs snapshot from 26. Feb.
Justin Hickey jhickey at hpcc.nectec.or.th
Tue Mar 6 03:25:24 EST 2001
Hi Andreas
Andreas Lange wrote:
> before making sockets default, could someone help me to get the
> sockets setup to compile on IRIX with gcc?
> Adding -lsocket to XEXTRALIBS does not help to compile all modules,
> as the d.* modules do not link the Xlibs. I can compile the XDRIVER24
> now, but many other modules still do not compile.
Strange. I don't need -lsocket at all for IRIX with MIPSPro compilers. I
didn't think different compilers would link differently. I thought
linking was more system dependent than compiler dependent. In fact, even
with gcc, don't you need the SGI C libraies installed?
> Adding -lsocket to all modules does not help too, there seems to be
> some problem with the library order on the linker command line?
Where did you add it? I would try adding it to the MATHLIB definition in
src/CMD/head/head.in. Of course, the "correct" way to do it is to add it
to each module that needs it. I suppose configure.in should set a make
variable and this variable be added to the compile lines of modules that
need socket code. A bit tedious but not that daunting a task. I'd do it
myself, but I don't have time this week.
> How was the problem solved with Solaris?
> Please do not assume that everything is ok if you recieve no feedback
> within a day ;-).
But we had positive feedback for IRIX from me. We just didn't think a
different compiler would cause a problem. :-(
Taken from your earlier post
> ./configure --bindir=/usr/people/andreas/bin \
> --with-socket \
> --enable-postgres=no \
> --with-jpeg-includes=/usr/freeware/include \
> --with-jpeg-libs=/usr/freeware/lib32 \
> --with-tiff-includes=/usr/freeware/include \
> --with-tiff-libs=/usr/freeware/lib32 \
> --with-tcltk-includes=/usr/freeware/include \
> --with-tcltk-libs=/usr/freeware/lib32 \
> --with-opengl-includes=/usr/include/GL \
> --with-opengl-libs=/usr/lib32
Did you try running configure without specifying the freeware
directories? I changed configure.in to add the freeware directories if
the machine is an SGI. Simply running configure without options now
works for me.
> Problem starting grass5:
> "Sorry, I need to know a more specific terminal type than ""."
> grass5 -tcltk works!
> grass5 -text does not work.
> export TERMINAL=ansi does not help.
Shouldn't that be TERM=ansi? At least that is the environment variable I
have on my machine.
I hope some of this helps.
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
