[GRASS5] Forgot the domail.pl script. oops.
Eric Mitchell
emitchell at altaira.com
Mon Mar 5 06:53:18 EST 2001
also attached the dolog.pl script, as I can't remember
which does what now...
| Eric B. Mitchell mailto:emitchell at altaira.com |
| tel: (301) 809 - 3534 Altair Aerospace Corporation |
| tel: (800) 7 - ALTAIR 4201 Northview Dr. Suite 410 |
| fax: (301) 805 - 8122 Bowie, MD 20716 |
,___
/"\ / o=\ /"""---===/
/ \_/ \__/ ---===/
| //\ || /""TT""/ //\ || ||""\
| // \ || || // \ || ||__/
| //--==\ |L--/ || //--==\ || || "=,
\____---===/
#! /usr/bin/perl
# -*- Mode: perl; indent-tabs-mode: nil -*-
# The contents of this file are subject to the Netscape Public License
# Version 1.0 (the "License"); you may not use this file except in
# compliance with the License. You may obtain a copy of the License at
# http://www.mozilla.org/NPL/
# Software distributed under the License is distributed on an "AS IS"
# basis, WITHOUT WARRANTY OF ANY KIND, either express or implied. See the
# License for the specific language governing rights and limitations
# under the License.
# The Original Code is the Bonsai CVS tool.
# The Initial Developer of the Original Code is Netscape Communications
# Corporation. Portions created by Netscape are Copyright (C) 1998
# Netscape Communications Corporation. All Rights Reserved.
# You need to put this in your CVSROOT directory, and check it in. (Change the
# first line above to point to a real live perl5.) Add "dolog.pl" to
# CVSROOT/checkoutlist, and check it in. Then, add a line to your
# CVSROOT/loginfo file that says something like:
# ALL $CVSROOT/CVSROOT/dolog.pl -r /cvsroot bonsai-checkin-daemon at my.bonsai.machine
# Replace "/cvsroot" with the name of the CVS root directory, and
# "my.bonsai.machine" with the name of the machine Bonsai runs on.
# Now, on my.bonsai.machine, add a mail alias so that mail sent to
# "bonsai-checkin-daemon" will get piped to handleCheckinMail.tcl.
# The first argument to handleCheckinMail.tcl is the directory that
# bonsai is installed in.
use Socket;
$username = $ENV{"CVS_USER"} || getlogin || (getpwuid($<))[0] || "nobody";
$envcvsroot = $ENV{'CVSROOT'};
$cvsroot = $envcvsroot;
$flag_debug = 0;
$flag_tagcmd = 0;
$repository = '';
$repository_tag = '';
$mailhost = 'localhost';
$rlogcommand = '/usr/bin/rlog';
@mailto=();
$mailfrom = 'domail at altaira.com';
@changed_files = ();
@added_files = ();
@removed_files = ();
@log_lines = ();
@outlist = ();
$STATE_NONE = 0;
$STATE_CHANGED = 1;
$STATE_ADDED = 2;
$STATE_REMOVED = 3;
$STATE_LOG = 4;
&process_args;
if ($flag_debug ){
print STDERR "----------------------------------------------\n";
print STDERR "LOGINFO:\n";
print STDERR " pwd:" . `pwd` . "\n";
print STDERR " Args @ARGV\n";
print STDERR " CVSROOT: $cvsroot\n";
print STDERR " who: $username\n";
print STDERR " Repository: $repository\n";
print STDERR " mailto: @mailto\n";
print STDERR " mailfrom: $mailfrom\n";
&mail_notification;
0;
sub process_args {
while (@ARGV) {
$arg = shift @ARGV;
if ($arg eq '-d') {
$flag_debug = 1;
print STDERR "Debug turned on...\n";
} elsif ($arg eq '-f') {
$mailfrom = shift @ARGV;
} elsif ($arg eq '-r') {
$cvsroot = shift @ARGV;
} elsif ($arg eq '-t') {
$flag_tagcmd = 1;
last; # Keep the rest in ARGV; they're handled later.
} elsif ($arg eq '-h') {
$mailhost = shift @ARGV;
} else {
push(@mailto, $arg);
if( $repository eq '' ){
open( REP, "<CVS/Repository");
$repository = <REP>;
chop($repository);
close(REP);
$repository =~ s:^$cvsroot/::;
$repository =~ s:^$envcvsroot/::;
if (!$flag_tagcmd) {
if( open( REP, "<CVS/Tag") ) {
$repository_tag = <REP>;
chop($repository_tag);
close(REP);
sub get_response_code {
my ($expecting) = @_;
# if ($flag_debug) {
# print STDERR "SMTP: Waiting for code $expecting\n";
while (1) {
my $line = <S>;
# print STDERR "SMTP: $line";
if ($line =~ /^[0-9]*-/) {
next;
if ($line =~ /(^[0-9]*) /) {
my $code = $1;
if ($code == $expecting) {
# print STDERR "SMTP: got it.\n";
return;
die "Bad response from SMTP -- $line";
sub mail_notification {
chop(my $hostname = `hostname`);
my ($remote,$port, $iaddr, $paddr, $proto, $line);
$remote = $mailhost;
$port = 25;
if ($port =~ /\D/) { $port = getservbyname($port, 'tcp') }
die "No port" unless $port;
$iaddr = inet_aton($remote) || die "no host: $remote";
$paddr = sockaddr_in($port, $iaddr);
$proto = getprotobyname('tcp');
socket(S, PF_INET, SOCK_STREAM, $proto) || die "socket: $!";
connect(S, $paddr) || die "connect: $!";
select(S); $| = 1; select(STDOUT);
get_response_code(220);
print S "HELO $hostname\n";
get_response_code(250);
print S "MAIL FROM: cvs-commits-list\@$hostname\n";
foreach $i (@mailto) {
print S "RCPT TO: $i\n";
print S "DATA\n";
get_response_code(354);
# Get one line starting with "354 ".
print S "Subject: cvs commit to $repository\n";
print S "\n";
while (<STDIN>) {
chop; # Drop the newline
if( $flag_debug){
print STDERR "$_\n";
push(@outlist, "$_\n");
print S @outlist, "\n";
print S ".\n";
print S "QUIT\n";
close(S);
#! /usr/bin/perl
use Socket;
$flag_debug = 0;
$flag_tagcmd = 0;
$repository = '';
@mailto=();
@added_files = ();
@log_lines = ();
@outlist = ();
$STATE_NONE = 0;
$STATE_CHANGED = 1;
$STATE_ADDED = 2;
$STATE_REMOVED = 3;
$STATE_LOG = 4;
&process_args;
if ($flag_debug ){
if ($flag_tagcmd) {
&process_tag_command;
} else {
&get_loginfo;
&process_cvs_info;
if( $flag_debug){
print STDERR @outlist;
&mail_notification;
0;
sub process_args {
while (@ARGV) {
$arg = shift @ARGV;
if ($arg eq '-d') {
$flag_debug = 1;
$flag_tagcmd = 1;
} else {
chop($repository);
close(REP);
close(REP);
sub get_loginfo {
if( $flag_debug){
# Iterate over the body of the message collecting information.
while (<STDIN>) {
if( $flag_debug){
if (/^In directory/) {
next;
if (/^Modified Files/) { $state = $STATE_CHANGED; next; }
if (/^Added Files/) { $state = $STATE_ADDED; next; }
if (/^Removed Files/) { $state = $STATE_REMOVED; next; }
if (/^Log Message/) { $state = $STATE_LOG; next; }
s/^[ \t\n]+//; # delete leading whitespace
s/[ \t\n]+$//; # delete trailing whitespace
if ($state == $STATE_CHANGED) { push(@changed_files, split); }
if ($state == $STATE_ADDED) { push(@added_files, split); }
if ($state == $STATE_REMOVED) { push(@removed_files, split); }
if ($state == $STATE_LOG) { push(@log_lines, $_); }
if( $flag_debug){
. "changed files: @changed_files\n"
. "added files: @added_files\n"
. "removed files: @removed_files\n";
sub process_cvs_info {
local($d,$fn,$rev,$mod_time,$sticky,$tag,$stat, at d,$l,$rcsfile);
if (!open(ENT, "<CVS/Entries.Log" )) {
open(ENT, "<CVS/Entries");
$time = time;
while( <ENT> ){
chop;
($d,$fn,$rev,$mod_time,$sticky,$tag) = split(/\//);
$stat = 'C';
for $i (@changed_files, "BEATME.NOW", @added_files ) {
if( $i eq "BEATME.NOW" ){ $stat = 'A'; }
if($i eq $fn ){
$rcsfile = "$envcvsroot/$repository/$fn,v";
if( ! -r $rcsfile ){
$rcsfile = "$envcvsroot/$repository/Attic/$fn,v";
open(LOG, "$rlogcommand -N -r$rev $rcsfile |")
|| print STDERR "dolog.pl: Couldn't run rlog\n";
while(<LOG>){
if (/^date:.* author: ([^;]*);.*/) {
$username = $1;
if (/lines: \+([0-9]*) -([0-9]*)/) {
$lines_added = $1;
$lines_removed = $2;
close( LOG );
push(@outlist, ("$stat|$time|$username|$cvsroot|$repository|$fn|$rev|$sticky|$tag|$lines_added|$lines_removed\n"));
close(ENT);
for $i (@removed_files) {
push( @outlist, ("R|$time|$username|$cvsroot|$repository|$i|||$repository_tag\n"));
push (@outlist, "LOGCOMMENT\n");
push (@outlist, join("\n", at log_lines));
push (@outlist, "\n:ENDLOGCOMMENT\n");
sub process_tag_command {
local($str,$part,$time);
$time = time;
$str = "Tag|$cvsroot|$time";
while (@ARGV) {
$part = shift @ARGV;
$str .= "|" . $part;
push (@outlist, ("$str\n"));
sub do_commitinfo {
while (1) {
my $line = <S>;
next;
my $code = $1;
return;
$port = 25;
print S "MAIL FROM: bonsai-daemon\@$hostname\n";
print S "DATA\n";
if ($flag_tagcmd) {
print S "Subject: cvs tag in $repository\n";
} else {
print S "\n";
print S ".\n";
print S "QUIT\n";
close(S);
