[GRASS5] open GRASS in own xterm
Markus Neteler neteler at geog.uni-hannover.de
Mon Mar 5 11:33:10 EST 2001
On Mon, Mar 05, 2001 at 04:50:39PM +0100, Bernhard Reiter wrote:
> On Mon, Mar 05, 2001 at 04:24:56PM +0000, Markus Neteler wrote:
> > Hi all,
> > as new users tend to start "grass5" with a double click in
> > a file explorer (especially the (former) Windows users) it
> > might be a good idea to start GRASS in an own "xterm" *if*
> > the DISPLAY variable is set (= Xwin running). This click-idea
> > of course doesn't currently work.
> Dont't,
> this is a task which the file manager has to solve.
> You can set the right options there.
> GRASS cannot do much about.
> (And it should not try.)
Sorry, why?
What about users starting GRASS in
KDE-> K->execute
Then GRASS crashes as well.
As GRASS needs a shell window, why not coding that?
 Markus
> > Starting GRASS in its own xterm would reduce lot of confusion
> > for them... Any objections?
> > We could use the same check mechanism already used for the
> > graphical startup.
> > Regards
> >  Markus
> > If you want to unsubscribe from GRASS Development Team mailing list write to:
> > minordomo at geog.uni-hannover.de with
> > subject 'unsubscribe grass5'
> Professional Service around Free Software                (intevation.net)
> The FreeGIS Project                                         (freegis.org)
> Association for a Free Informational Infrastructure            (ffii.org)
> FSF Europe                                            	  (fsfeurope.org)
Markus Neteler *  University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494  Fax: -3984
