[GRASS5] grass cvs snapshot from 26. Feb.
Justin Hickey jhickey at hpcc.nectec.or.th
Mon Mar 5 05:00:01 EST 2001
Hi Markus
Markus Neteler wrote:
> However, how to tell configure.in about it?
> It seems to be an autoconf bug (see configure):
>   for ac_prog in 'bison -y' byacc
> should be
>   for ac_prog in 'bison -y' byacc yacc
> How can we fix this?
I'm basically brain dead when it comes to using configure.in but
according to the texinfo file for autoconf we have the following:
 - Macro: AC_PROG_YACC
     If `bison' is found, set output variable `YACC' to `bison -y'.
     Otherwise, if `byacc' is found, set `YACC' to `byacc'.  Otherwise
     set `YACC' to `yacc'.
So I don't think there should be a problem. To eliminate the warning
message maybe we need to add a check for byacc in configure.in as
follows
AC_PROG_YACC
if test "$YACC" != "bison -y"; then
  if test "$YACC" != "byacc" && test "$YACC" != "yacc"; then
    AC_MSG_WARN(You will need bison/yacc as required for various GRASS
modules.)
  fi
The rest of the code in configure.in checks the version of bison. I
don't know, just guessing.
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
