[GRASS5] grass cvs snapshot from 26. Feb.
Markus Neteler
neteler at geog.uni-hannover.de
Mon Mar 5 04:38:12 EST 2001
On Mon, Mar 05, 2001 at 11:53:36AM +0700, Justin Hickey wrote:
> Hi Markus
> Markus Neteler wrote:
> > Hi Andreas,
> > hi all bison/yacc friends,
> > I have added a "bison" test borrowed from PHP4. It searches for
> > bison and replaces the name in the head file.
> > However, it doesn't seem to recognise "yacc" properly if bison is
> > not present (I don't fully understand the bison test).
> > On Linux no problem, but the CRAY complains (as usual):
> > checking for flex... lex
> > checking for yywrap in -ll... yes
> > checking for bison... no
> > checking for byacc... no
> Is the "b" correct, or should it be looking for just "yacc"?
> Just a wild guess without looking at any code.
Bingo! But I just changed in "configure"...
checking for yacc... yacc
configure: warning: You will need bison/yacc as required for various GRASS
modules.
However, how to tell configure.in about it?
It seems to be an autoconf bug (see configure):
for ac_prog in 'bison -y' byacc
should be
for ac_prog in 'bison -y' byacc yacc
How can we fix this?
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
