[GRASS5] GRASS stable/exp branches
Justin Hickey jhickey at hpcc.nectec.or.th
Mon Mar 5 02:09:32 EST 2001
Hi Markus
Markus Neteler wrote:
> On Fri, Mar 02, 2001 at 06:20:05PM +0700, Justin Hickey wrote:
> > Hi Markus
> > > maybe we can feed the src/CMD/lists/GRASS to cvs through
> > > a pipe to set the release branch tag? Then we maintain
> > > the lists/GRASS and all commented modules there won't
> > > receive the tag. Just an untested idea.
> > > I can't try right now due o hardware problems which should
> > > be fixed in some minutes.
> > Interesting idea. The only problem is removing the commented lines.
> > I don't think cvs will ignore them. But you could remove them using
> > sed. So it would be something like
> > cat src/CMD/lists/GRASS | sed ...... | cvs .....
> > right?
> > Anyway, I think it could work, just not sure you can pipe file
> > names to cvs.
> Obviously not. But this one seems to work:
> FILE_LIST=`cat src/CMD/lists/GRASS | grep -v '#'` ; cvs .. $FILE_LIST
Duhh!! I don't know where my head was for that one! It's hard to believe
I wrote that. :-)
> So my proposal is to update the src/CMD/lists/GRASS (comment all
> unstable files), then use this list as branch tagging input (easy to
> maintain, easy to reproduce).
Sounds good to me.
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
