[GRASS5] GRASS stable/exp branches
Markus Neteler
neteler at geog.uni-hannover.de
Sat Mar 3 05:59:15 EST 2001
On Fri, Mar 02, 2001 at 06:20:05PM +0700, Justin Hickey wrote:
> Hi Markus
> Markus Neteler wrote:
> > maybe we can feed the src/CMD/lists/GRASS to cvs through
> > a pipe to set the release branch tag? Then we maintain
> > the lists/GRASS and all commented modules there won't
> > receive the tag. Just an untested idea.
> > I can't try right now due o hardware problems which should
> > be fixed in some minutes.
> Interesting idea. The only problem is removing the commented lines. I
> don't think cvs will ignore them. But you could remove them using sed.
> So it would be something like
> cat src/CMD/lists/GRASS | sed ...... | cvs .....
> right?
> Anyway, I think it could work, just not sure you can pipe file names to
> cvs.
Obviously not. But this one seems to work:
FILE_LIST=`cat src/CMD/lists/GRASS | grep -v '#'` ; cvs .... $FILE_LIST
So my proposal is to update the src/CMD/lists/GRASS (comment all unstable
files), then use this list as branch tagging input (easy to maintain, easy
to reproduce). Later in 5.1 we need another method.
Cheers
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
