[GRASS5] Re:
Markus Neteler
neteler at geog.uni-hannover.de
Fri Mar 2 04:40:07 EST 2001
On Fri, Mar 02, 2001 at 03:54:15PM +0700, Justin Hickey wrote:
> Hi Markus
> Markus Neteler wrote:
> > Aha, I see. So no (easy!) way to distinct between the version error
> > and other tcl/tk errors?
> We could use the error code, but if the script fails due to a system
> error we don't know what that error code is. Thus, it is difficult to
> guarantee a unique error code.
> > Well, the version message is quite useful. In this case we should
> > keep the message as is (perhaps adding "libraries" to be very clear
> > here for newcomers).
> I changed the message to read as follows:
> Sorry your version of the Tcl/Tk libraries is 7.6 and is too
> old for GRASS which requires a Tcl/Tk library version of 8.0 or later.
> Reverting default settings back to GRASS text mode interface.
> Error in Tcl/Tk startup. If necessary, please
> Report this error to the Grass developers.
> Switching to text mode now.
> Hit RETURN to continue...
> If there is any other error the output is
> Is this OK?
Yes, perfect!
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
