[GRASS5] g.html2man: perl location problem
Justin Hickey jhickey at hpcc.nectec.or.th
Thu Mar 1 23:12:55 EST 2001
Hi Markus
Markus Neteler wrote:
> > Yes, perl has a similar method. The following is from the
> > "Programming Perl" book:
> > #!/bin/sh -- #perl, to stop looping
> > eval 'exec /usr/bin/perl -S $0 ${1+"$@"}'
> >     if 0;
> > .. rest of perl script ...
> > It's strange but it seems to work for me. In this case you simply
> > substitute maybe $GRASS_PERL for /usr/bin/perl.
> Looks funny! However, the "--" is not supported here:
> g.html2man
> sh: -- #perl, to stop looping: unrecognized option
> Usage:  sh [GNU long option] [option] ...
>         sh [GNU long option] [option] script-file ...
This is strange. -- is definitely a valid option for sh on Linux. You
can try it on the command line. In fact, I could not use *any* option
after #! /bin/sh, strange. So, I checked the perl newsgroup archive and
there was a post similar to this and the reply was that it was probably
a bug in the GNU sh. However, I found a workaround. Simply call
g.html2man with sh. That is:
sh g.html2man.
This should work, at least my test cases worked here on both Linux and
SGI.
> And also not the -S:
> export GRASS_PERL=/usr/bin/perl
> g.html2man
> /bin/sh: -S: unrecognized option
> Shall I simply remove these flags?
The -S option is an option to perl, not sh, so please do not remove it.
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
