[GRASS5] v.in,dxf
Rich Shepard rshepard at appl-ecosys.com
Fri May 18 11:17:46 EDT 2001
On Fri, 18 May 2001, Roger S. Miller wrote:
> Is anyone maintaining v.in.dxf?  Are there any plans to update or upgrade
> v.in.dxf, or to write a v.out.dxf?
Roger,
  v.in.dxf almost works. Let me clarify that: it may actually be working now
that I've built a new installation. I'll check that over the weekend.
  The potential problem with v.out.dxf is for which version of AutoCAD it
should be targeted. Apparently ACAD/2K is quite different from earlier
versions.
Rich
Dr. Richard B. Shepard, President
                       Applied Ecosystem Services, Inc. (TM)
            2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
 + 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard at appl-ecosys.com
