On Fri, May 25, 2001 at 06:26:26PM -0400, Robert Lagacé wrote: > > I found an error in configure line 3690 > > if test $tkincdir ; then > > should be > > if test "$tkincdir" ; then > > -- > Robert Lagacé, professeur Robert, thanks for the fix. I have updated in CVS. Hope you can compile the GRASS now. Regards Markus
