[GRASS5] Socket compilation error on HP-UX
Robert Lagacé
lagace at grr.ulaval.ca
Tue May 29 13:47:08 EDT 2001
I compile GRASS5 on HP-UX with a few errors. The most important one is
with socket. The compiler error is :
/local/grass5.0.0pre1/src/display/devices/lib
make -f OBJ.hppa1.1-hp-hpux10.20/make.rules
gcc -g -O2 -I/opt/libpng/include -I/local/grass5.0.0pre1/src/include
-c connect_sock.c -o OBJ.hppa1.1-hp-hpux10.20/connect_sock.o
connect_sock.c:9: sys/select.h: Fichier ou répertoire inexistant
*** Erreur - code de sortie 1
The <sys/select.h> is missing on HP-UX. What are the symbols that
"connec_socket.c" is looking for in this file so I look where they are.
Thanks.
Robert Lagacé, professeur
Pavillon Comtois
Université Laval
Ste-Foy, Québec, G1K 7P4
tel : (418)-656-2131#2276
Fax : (418)-656-3723
E-mail : lagace at grr.ulaval.ca
