[GRASS5] which tag?
Eric Mitchell
emitchell at altaira.com
Wed May 30 10:55:12 EDT 2001
However, you can update to the latest source by doing:
cvs update -A
or by doing a fresh checkout. This will clear the
"sticky" tag from checking out via a specified
revision/date.
Markus Neteler wrote:
> On Wed, May 30, 2001 at 04:12:03PM +0200, Andreas Lange wrote:
> > Hi,
> > one short question:
> > I checked out the release_grass500pre1_20_may_2001 version for testing.
> > If i update now with cvs update -dP nothing is updated.
> > Do i have to switch back to the release branch
> > releasebranch_11_april_2001_5_0_0 to get the new code?
> > I am a bit confused right now. The grasscvs page does not help too.
> Hi Andreas,
> please note that we have
> tags
> --+----+------------> exp (main) (currently unused)
> \ +tag: release_grass500pre1_20_may_2001
> +--------|--------------+-------> releasebranch_11_april_2001_5_0_0
> today
> You see that you may not mix tags on release_branch and the branch itself.
> Does this clear the situation?
> Regards
> Markus
> grass5 mailing list
> grass5 at geog.uni-hannover.de
> http://www.geog.uni-hannover.de/mailman/listinfo/grass5
| Eric B. Mitchell mailto:emitchell at altaira.com |
| tel: (301) 809 - 3534 Altair Aerospace Corporation |
| tel: (800) 7 - ALTAIR 4201 Northview Dr. Suite 410 |
| fax: (301) 805 - 8122 Bowie, MD 20716 |
,___
/"\ / o=\ /"""---===/
/ \_/ \__/ ---===/
| //\ || /""TT""/ //\ || ||""\
| // \ || || // \ || ||__/
| //--==\ |L--/ || //--==\ || || "=,
\____---===/
