[GRASS5] which tag?
mlennert at club.worldonline.be mlennert at club.worldonline.be
Wed May 30 11:54:19 EDT 2001
> On Wed, May 30, 2001 at 04:57:12PM +0200, Andreas Lange wrote:
> > Hi Markus,
> > thanks for the nice diagram. I am aware of the structure.
> > But how do i update my source directory, which i checked out with the
> > pre1 tag?
> > Do i have to use cvs update -r releasebranch_11_april_2001_5_0_0 and
> > then cvs up -dP ?
> > This is how it is described on the grasscvs.html page.
> > Sorry for my ignorance,
> Hi Andreas,
> sorry for my bad explanations... I guess a
> cvs up -dPA should help
> to remove the sticky tag.
So that means that for the new Linux binaries I should do a cvs of the
release_grass500pre1_20_may_2001 and then do a cvs up -dPA to be sure to have
the latest version ?
Moritz
(another cvs ignorant ;-) )
> > Markus Neteler wrote:
> > > On Wed, May 30, 2001 at 04:12:03PM +0200, Andreas Lange wrote:
> > > > Hi,
> > > > one short question:
> > > > I checked out the release_grass500pre1_20_may_2001 version for testing.
> > > > If i update now with cvs update -dP nothing is updated.
> > > > Do i have to switch back to the release branch
> > > > releasebranch_11_april_2001_5_0_0 to get the new code?
> > > > I am a bit confused right now. The grasscvs page does not help too.
> > > Hi Andreas,
> > > please note that we have
> > >  tags
> > > --+----+------------> exp (main)  (currently unused)
> > >           \         +tag: release_grass500pre1_20_may_2001
> > >            +--------|--------------+-------> releasebranch_11_april_2001_5_0_0
> > >                                   today
> > > You see that you may not mix tags on release_branch and the branch itself.
> > > Does this clear the situation?
> > > Regards
> > >   Markus
> > > _______________________________________________
> > > grass5 mailing list
> > > grass5 at geog.uni-hannover.de
> > > http://www.geog.uni-hannover.de/mailman/listinfo/grass5
> > Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
> > Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
> Markus Neteler *  University of Hannover
> Institute of Physical Geography and Landscape Ecology
> Schneiderberg 50 * D-30167 Hannover * Germany
> Tel: ++49-(0)511-762-4494  Fax: -3984
> grass5 mailing list
