[GRASS5] Socket compilation error on HP-UX
Glynn Clements
glynn.clements at virgin.net
Wed May 30 12:14:46 EDT 2001
Robert =?iso-8859-1?Q?Lagac=E9?= wrote:
> > > > > However, it appears that <sys/types.h> is the correct file to
> > > > > include.
> > > > This is still true. I'll change this.
> > > What are the symbols or functions defined there?
> > The ones for which <sys/select.h> was being used are the fd_set type
> > and the FD_ZERO and FD_SET macros. In GNU libc 2, these are defined in
> > <sys/select.h> but that file is included from <sys/types.h>. The
> > latter is apparently the correct file to include for these
> > definitions.
> On HP-UX 10.2, fd_set type and FD_ZERO and FD_SET macros are define in
> <sys/types.h>. If for other platforms, these definitions are as you
> said in <sys/select.h> but included from <sys/types.h>, it not
> necessary to put the include statement #include <sys/select.h> since
> #include <sys/types.h> is already present. The problem can only exist
> for systems where thoses definitions are not included directly or
> indirectly by <sys/types.h>. In those case, the include will be
> conditional. We need to identify those systems. HP-UX and LINUX
> seems OK.
> One tempory solution i may be change the following statements in
> connect_sock.c
[snip]
None of this is necessary; "#include <sys/types.h>" is sufficient.
Glynn Clements <glynn.clements at virgin.net>
